Humidity Sensor in a Humidor
I have a small humidor for a few of my cuban cigars. I rarely smoke, so I always forget to add water to my humidor. It would be nice to have a small humidity sensor report to the isy so when the variable reached under my specified target I get a notification. Anyone else do something this?
I'm in a similar situation.
We have a console humidifier (14 gpd unit) that uses those wicking filters. I've set up a float valve on it so that it is always full of water.
After 2-3 months the filters get saturated enough with calcium deposits that they need to be changed; but we never pay attention because it always has water.
Our solution is using the thermostat. The Insteon Thermostats have humidity sensors on them (I think the Z Wave does also) that is a variable you can access on ISY.
I have a disabled program that just sends a notification after 24 hours.
       Time is 11:55:00PM
       Wait  23 hours
       Send Notification to 'Admin' content 'Humidity Warning'
Then this program will enable / disable the program based on humidity:
       Status  'Thermostat- Main' < 50% (Humidity)
       Enable Program 'Humidity Notify'
       Set Program 'Humidity Notify' To Run At Startup
       Disable Program 'Humidity Notify'
       Set Program 'Humidity Notify' To Not Run At Startup
Some other things to note:
You could get a humidity sensor (such as with the 1 wire bus) and use that instead.
Also, if you are worried about the water getting low and you can't do a float like in mine, you may be able to hook up a leak sensor. Your program would trigger if a leak was not detected due to the water getting low and then you could fill it.
