Triggering a Scene using an Insteon OFF signal
Can somebody please point me to an example of how to create a scene where the scene is triggered by an Insteon OFF command?
I need to set up a scene where a sensor feeding an IOLinc turns OFF thereby turning on a KPL LED as a warning.
I've read and watched tutorials but for some reason this is eluding me.
A Scene is not defined as to what command will trigger the Scene. Not within Insteon capability. An ISY Program can be triggered with an Off command from a device and the Program issue an On command to the Scene.
If Control 'devicex' is switched Off
Set Scene xxxx On
where Scene xxxx has the KPL button as a Responder
