Venstar - Can't control thermostat via 2441V
good morning -
worked for 2 days- no issues ...I did a diag -query insteon engine/hard reset of the Dongle ..
ISY sees the Dongle.. but the error is between the dongle and Thermostat.
and just to confirm... I did install it with Thermostat in OFF position ..
the ONLY thing I did yesterday was update the firmware and UI to 4.2.2 .... could this be something.. ?
can I revert to an older firmware ? .. and confirm.. is this easy to do ?
thank you
Inexplicably.. it just went back online.. not the best confidence booster ..
Has anyone else seen something similar ?
thank you
Matt
