Getting phantom Email Notifications - help!
I had setup an email notification to be sent when a motion detector low battery signal provided a status of ON. The ISY-994 program looks like this:
If Time is 8:00PM
And Status 'Motion1-Low Bat' is ON
Then Send Notification to '...' content 'Low Battery Motion1'
When the battery got low, I indeed received a notification, but at 1:00am. First thing, why the time difference? Is there a time zone translation I've missed somewhere? Does the ISY use GMT?
But then the bigger problem: After I replaced the battery, I confirmed the 'Low Bat' status returned to OFF. BUT!!!...I continue to get the notification email every evening at 1:00am. I even disabled the program, but am still getting the email notification DAILY. What is going on?! Help ;)
There is another Program that is sending an email. Also normally it is necessary to right click on Low Batt node and select Query to reset the node to Off.
Yep! Now I see it. I had copied a DAY-MONTH-YEAR calendar routine that has some email notification function built in. Now I need to figure out what its purpose is. Thanks! Most of the mystery solved.
