First timer needs a bit of help with thermostat control code
Hello all,
First timer here. I just picked up an ISY, insteon wired and wireless thermostat (plus a few on/off modules). I am in the process of implementing a whole house fan strategy that runs the whole house fan in lieu of my AC, if my outside temperature is lower than the inside temp. In short, i have all this working.
Here's what i havent figured out yet:
When each program runs to query my thermostats, they only run once. So if my thermostat happens to be 75 degrees when the whole house fan kicks, My whole house fan will stay on until the next scheduled time that the program has listed (the end time for that program). I have not figured out how to write a repeat loop for the program, so that it re-runs say, every 10m (re-checks thermostat temps, checks it's run times and adjusts accordingly).
I hope that this is an easy fix. The query that I wrote to re-query both thermostats every 10m doesn't seem like the fix :/
Here is a some of the code I am trying:
WHF_AWAY:
Status 'Outside' > 45° (Temperature)
Or Status 'Outside' < 72° (Temperature)
And Status 'MainThermostat' >= 68° (Temperature)
And On Mon, Tue, Wed, Thu, Fri
From 7:00:00AM
To 1:59:00PM (same day)
Set 'FAN1' On
Send Notification to 'Default' content 'FANON'
Set 'MainThermostat' Mode Off
Set 'FAN1' Off
Set 'MainThermostat' Mode Cool
Send Notification to 'Default' content 'FANOFF'
WHF_HOME:
Or Status 'Outside' < 69° (Temperature)
From 2:00:00PM
To 6:59:00AM (next day)
Set 'FAN1' On
Set 'FAN1' Off
WHF_WEEKENDS:
And Status 'MainThermostat' > 71° (Temperature)
And On Sat
From 7:00:00AM
To 11:59:00PM (same day)
Or On Sun
From 12:01:00AM
Set 'FAN2' On
Set 'FAN2' Off
I'd love some help on a more optimized approach as well.
Thanks in advance for any help!
For mine I set a wait command and then call the same program's If Path. Below is an example of my program Equalize that is set up for a similar reason. It will run the whole house fan when some fan switches are used or if I'm at one of my heating / cooling setpoints.
       Status  'Office Light - Office Light / Office Light - Fan High' is not Off
    Or Status  'Closet Light - Closet Light / Closet Light - Fan High' is not Off
    Or $Int_Main.TStat_Status is $Int_Main.TStat_SP.Cool_Actual
    Or $Int_Main.TStat_Status is $Int_Main.TStat_SP.Heat_Actual
       Set 'Main - Thermostat' Fan On
       Wait  10 minutes
       Run Program 'Equalize' (If)
       Set 'Main - Thermostat' Fan Auto
       Wait  10 minutes
Thank you for this example. I'll play around today and see what i can do with it.
       Wait  10 minutes
       Wait  10 minutes
That did the trick! Now I get to move on to installing actuated and filtered fresh air inlets around the house. Thanks again.
I would be interested how you go about doing that.
Right now I'm installing a 12" line to bring fresh air into the house by connecting it to the suction side of my whole house fan. It as a NC Damper on it that I'll throw some programs together to handle the opening and closing.
I'm having that line run through its own filter at the suction.
The rest of the dampers are just zone controls for the various rooms. It is not often the weather is cool enough here that we can run without the AC.
So far, I will be starting my first inlet very similar to what you described. Unfortunately, my house is all HIP roof. Sooo, I will need to do a roof penetration, or get really creative with freeze blocks. I actually plan on doing both.
For the roof penetration, I plan on running one of these: https://www.acwholesalers.com/Fantech/R ... fgodaDAAGw
I will have to remove the damper.
I will run this http://www.smarthome.com/3086/12-Inch-D ... DNC/p.aspx inline, and on the same scene as the whole house fan.
I will be terminating the ducting in my ceiling with one of these: http://www.homedepot.com/p/Master-Flow- ... /100168335 with a standard furnace filter and grill. The filter will just be flipped.
Rinse and repeat for multiples.
Ok. Here is the sorted out code fir anyone that wants to play around with whole house fan / Thermostat control. Seems to work well so far. Thanks!
I have 3 different programs that run. WHF_Home, WHF_Away and WHF_Weekend.
I use 3 triggering programs to determine when they need to be run. These are named HOME, AWAY, WEEKEND. These triggering programs disable 2 of the 3 programs at any point in time when the criteria is met.
AWAY:
       From     7:00:00AM
       To       6:59:00PM (same day)
       Run Program 'WHF_AWAY' (If)
       Disable Program 'WHF_AWAY'
HOME:
       From     2:00:00PM
       Run Program 'WHF_HOME' (If)
       Disable Program 'WHF_HOME'
Weekend:
       On Sat, Sun
       From     7:00:00AM
       Run Program 'WHF_WEEKEND' (If)
       Disable Program 'WHF_WEEKEND'
WHF_AWAY:
       Status  'Outside' <= 70° (Temperature)
   And Status  'MainThermostat' >= 60° (Temperature)
   And Status  'MainThermostat' <= 70° (Temperature)
       Set 'FAN1' On
       Wait  20 minutes
       Set 'FAN1' Off
       Wait  10 minutes
WHF_HOME:
   And Status  'MainThermostat' >= 70° (Temperature)
       Set 'FAN1' On
       Wait  20 minutes
       Set 'FAN1' Off
       Wait  10 minutes
WHF_WEEKEND:
       Status  'Outside' <= 72° (Temperature)
       Set 'FAN1' On
       Wait  20 minutes
       Set 'FAN1' Off
       Wait  10 minutes
I like how they look. Do you have the triggers set to run on boot as well?
Not yet. I wanted to make sure all was well first. I actually just found that I forgot to add lines to re-enable the programs when the time criteria was met.
So the home, away and weekend will look like so:
       From     7:00:00AM
       Enable Program 'WHF_AWAY'
