Wait or Repeat interrupted in a disabled program?
Curious about this, if you have a program
if
  status  is on
then
  wait 10 minutes
  set  off
else
I understand that normally if the state of changes the "wait" is interrupted and the "if" is re-evaluated. But does this happen if you are running (if) the program manually and it is disabled?
A Disabled Program is not affected by state change.
Watch Programs | Summary page. Run the Program manually and follow the Activity column as state changes in Disabled Program. The Else clause does not run when state changed.
Thanks Lee. It occurred to me that may be the case but I wanted to check. Of course my real program was with a 1 second delay so it was hard to determine visually.
