Any clever ideas?
Just switched from AT&T to T-Mobile. AT&T had separate Email addresses for SMS or MMS. T-Mobile only has one and will use MMS if the length is over 160 characters.
Trying to send a short notification from the ISY but force MMS to be used. A small picture would not be out of the question if there was a way to get ISY to include it. Or are there invisible characters that can be used that will pad the message but not show up in the actual message? What do the HTML and XML options in the custom notifications screen do. If I could code a message in HTML that could easily use up 160 characters?
Why do you need it sent as MMS?
Sent from my SM-N900P using Tapatalk
I have an iPhone. If I receive an SMS it shows as coming from "402-7" or something like that. Different number each time. The text of the message is / / .
If it's sent as MMS it's like Email, the from Email is looked up in contacts and displays the actual name and the subject is bolded and the message is below that. Much prettier. Easy to see and take notice or ignore at a glance.
