Problem with IOLincs sending status events
I have had 2 IOLinc devices attached to my garage doors. Things worked fine initially & due to focus in other areas, stopped using them with my HA set-up. However, this past weekend I tried to incorporate them into some of my programs & noticed that my ISY i994 Pro does not hear any status changes on either device. However, if I manually query them from the Admin Console or Mobilinc, they correctly report their status.
Both relays work perfect...garage doors are going up & down perfectly, every time. Also, in this particular house I haven't run into any communications problems that interfere with Insteon.
I have debugged with the Event Viewer (Level 3) & there is no activity when I press the garage button and the door goes up (thus no change in the status). However, as soon as I query the device, I see the activity & the status is correct. I also have visually watched the LED on the side of the IOlinc flash when open/closure occurred.
If this were happening with just one device, I would assume the other one flaked out. But, with both of them acting this way, plugged into different circuits, makes me think that I'm missing something.
The only options that I have set are LED on TX and Momentary B.
Does any one have any suggestions? Thanks in advance!
BTW, I'm using 4.2.3 of the ISY software.
Suggest running a Restore Device on the I/O Lincs. All the items noted working do not require link records. The reporting of Sensor status change requires a link record in the I/O Linc and the PLM.
Lee - thank you so much! That did the trick!
