modify fanlinc speeds
Does anyone know if you can increase the amount of power that a fanlinc uses at each setting? The fan speed at the low setting is pretty ineffective for my room and I would like to speed it up. The fan does not have a pull chain but when I set the fanlic on high the fan gets moving pretty fast so having the setting rights on the fan isn't the issue. I'm hoping there is some way you can set the low setting on the fanlinc to like 50% or something like you would on a dimmer.
Any suggestions?
