Replacement 99iPro by 994iPro - X10 problem
I just replaced my ISY 99i for the 994i. Everything seems to work fine until I discover X10 receiving issue.
I follow the recommended process. Downgrade the new ISY (994i) to latest 99i firmware. Restore from backup.
Upgrade to 4.2.4. Transfer the modules (Weather, Networking, A10/X10) to the new 994i.
ISY is able to send X10 messages. I see the messages in the Event Viewer. I have a few buzzers and the work fine.
But ISY is not receiving X10 message. Nothing in the Event Viewer (level 3). My alarm system send X10 messages when doors are open and close.
I have a X10 console to generate X10 message to confirm the problem in different home outlets.
I upgrade to 4.2.5 this morning. Same problem.
I suspected the PLM (2412S v85). Factory Reset and restore. Same problem. The PLM has 474 links. Total of 125 Insteon devices.
I have a spare PLM (2412S v72) that I try. Factory Reset without a restore just to see X10 message. Still no X10 message.
I also install the local power to 994i. With or without, same problem.
Everything has been stable and fine for years with 99i. What else should I try? Do I have a defective PLM? Shall I reset and restore ISY?
Thank you in advance for your help.
Robin
It is not the ISY. Here is event trace of X10 being received from X10 controller.
Sat 06/28/2014 01:19:52 PM : [X10-RX ] 02 52 56 00
Sat 06/28/2014 01:19:52 PM : [ X10] G1
Sat 06/28/2014 01:19:54 PM : [X10-RX ] 02 52 53 80
Sat 06/28/2014 01:19:54 PM : [ X10] G1/Off (11)
Sat 06/28/2014 01:19:54 PM : [X10-RX ] 02 52 56 00
Sat 06/28/2014 01:19:56 PM : [ Time] 13:20:00 1(0)
Sat 06/28/2014 01:19:59 PM : [X10-RX ] 02 52 56 00
Sat 06/28/2014 01:19:59 PM : [ X10] G1
Sat 06/28/2014 01:20:01 PM : [X10-RX ] 02 52 53 80
Sat 06/28/2014 01:20:01 PM : [ X10] G1/Off (11)
Sat 06/28/2014 01:20:01 PM : [X10-RX ] 02 52 56 00
Try plugging the X10 controller into the same circuit the PLM is on.
  • 4 weeks later...
LeeG,
A couple of week later, time to troubleshoot, to order, and to replaced the defective X10 PSC-04 module. Everything is working fine.
Thank You,
Robin
