Keypadlinc question (updating a scene)
Hi I have a question on updating a scene a my 8 key keypadlinc. I have a button "Guests" that dims the family room can lighting. I recently changed over the bulbs to LED's and needed to change the dim levels on the scene. It was my understanding that when a scene was changed that it updated any buttons that the scene was associated with. Am I wrong in that assumption? (I have a 994i series system) If I activate the scene from any other place, Administrative console, or Mobilinc it uses the new settings. But the Keypad doesn't.
Any help or advice would be greatly appreciated
You need to copy the new scene settings to each controller.
In the ISY Admin Console, you will need to expand the scene, click the controller you want to adjust settings for (it will be red). Then click "Copy Scene Attributes from "
In general, this allows you to define a scene once, and have different setting for each device when controlled from different controllers. The name scene name is when ISY is the control (Admin console, dashboard, programs).
Thank you PurdueGuy, that worked. I learn something new that this system does. It is very complex and I'm sure I have only touched the surface.
Thanks again for you help
Steve
