Weatherbug not working?
I don't normally have to log into my isy-994i much, but I did today to look at some things.  I went to the climate tab, and under status everything says 0 for all the weather options..
I thought maybe my local weatherbug feed was down (even though its a NWS feed from a major airport), so I went to find and put in my zip code as well as the local metro zip code.  No stations are being found... is weatherbug down, or do I have an issue of some sort?
WeatherBug is no longer a valid source of data, to a change in how they license data access. You need to upgrade your ISY to switch to HAM Weather.
also when using HAMWeather you'll need to search by city name as it doesn't recognize zip codes. It's best to upgrade to the current ISY firmware as it addressed some climate bugs.
Edited by Techman
