Can ISY994i and HouseLinc both run on same house wiring??
I want to run HouseLinc to run a Smartenit 8 zone irrigation system along with a ISY-994i both will have their own 2413S plug into house wiring, will they interfer with each other, can I get this to work?
If both setups are completely independent. They should work.
Problems happen if you have Insteon devices common to both controllers. Each one does not know the other system exists and can overwrite links in the modules. Not known to the controller.
Edited by Brian H
