Filter Linc - Replacing the fuse
I was very fortunate last year to pick up quite a few Filter Lincs. In the box were the smaller 5 amp versions. I would like to replace the 5 amp fuse with the 10 amp fuse.
But, wanted to confirm what type of fuse this is?
It appears to be a glass slow blow fuse inside of the two retaining clips.
F2FE6C43-166F-40EE-9928-3C6781461005_zpsA38ECC81-4A36-4644-ABE9-DB52D724D407_zps
normally they have their values and I look at the element itself to determine slowblow or not, always difficult without superman vision.  maybe look  on the FCC or UL websites to see what the schematics say they are?
You may also want to check the other components on the board to may sure that they are rated for the higher wattage/current before you change the fuse.
I have compared the five and ten amp versions.
As far as I have found. They charged more for the ten amp one and the only difference is the fuse.
I will check my notes and see if I have the fuse value archived.
No the fuse is not in any clips. They are the axial lead type that are soldered to the PCB.
Schematic I found on line for the ten amp one.
http://home.comcast.net/~gafield/family/gary/electronics/X10_Filter.pdf
Edited by Brian H
From my notes:
5mm X20mm
10 Amp 250 volt Fast acting
Axial Lead Connections
Ceramic Body.
From the X10 Forums.
http://forums.x10.com/index.php?topic=26713.0
Hello Brian H,
Much thanks for providing the specs and the dimensions of the fuse for the Filter Linc! If anyone can source these fuses on the cheap please do let me know.
Otherwise I am on the hunt for about ten of these.
These links from the X10 forums should give you some information.
You can use the part numbers to look locally.
 http://www.mouser.com/ProductDetail/Littelfuse/0216010MXESPP/?qs=PoXZt%252b2CjAAfgOqh60qsGQuqbta%252b5Avq5CfjV9vr4Ok%3d
 http://www.mouser.com/ProductDetail/Littelfuse/0216010MXEP/?qs=8QfiMw8FY5NmcLOlEFnlJJVROeGEXRmOLix439D6RVU%3d
The Littlefuse specifications sheets are on the Mouser web pages. If memory serves me. One is slightly shorter as the leads are directly welded to the ends and the other one has the added end leaded caps like the originals.
Edited by Brian H
Brian H,
Once again, I thank you!
  • 4 months later...
Teken, which one and source did you end up using for them?  I have a filterlinc that did not like being on my microwave oven long term and I'm sure just burned up the fuse..
Apologies for the tardy reply.
I never got around to doing the change over because got distracted by other pressing matters. If you find anything please do let me know and maybe we can do a purchase together.
I only have two left out of the ten (5 amp) version left anyways. As I friend ask if he could have a few for his install and would be using it with in its amperage range.
That saved me a few bucks and time changing those eight over.
The original fuse is a 10 amp fast acting.
Overtime the short start up current surge from the microwave may have weakened the fuse and it eventually opened up.
Both of the linked ones should fit.
This is the slightly longer one and looks closer {though I have not done a physical measurement of the original}
http://www.mouser.com/ProductDetail/Littelfuse/0216010MXEP/?qs=8QfiMw8FY5NmcLOlEFnlJJVROeGEXRmOLix439D6RVU%3D
Edited by Brian H
Brian H,
As always I thank you . . .
I've soldered in a pigtail fuse and left the old fuse in place. There's plenty of room. Some years back there were S-shaped clips, but I can't find any now.
I have similar fuse holders but they have mounting feet.
