IR PIR Scene help
Hello everyone.. not sure how to code the following
I have a INSTEON PIR and Id like it to trigger my front lights that would already be at 50% to 100% and after 5 mins.. return to 50%
So..
Front lights on at 50% at Sunset
       IR PIR triggers
                 Front Lights Increases to 100%
                        WAIT 5 MIN
                            Down to 50% till next trigger
     IF :
       From    Sunset  +  1 minute and  1 second
       To      Sunrise +  1 second (next day)
       And Status 'Front PIR-Sensor' is On
    Then :
        Set 'Front Door' 100%
        Wait  5 minute and 10 seconds
        Set 'Front Door' 50%
does the trigger.. 100% bright
after 5 mins... nothing ..does not execute the 50% dim level...
Im not sure what Im doing wrong
thanks !
Edited by mzn50
Anytime you use a program rather that a scene, a delay is introduced. For an immediate response, wire a Micro On/Off Module in parallel with the dimmer that operates the front lights and link the MS to the Micro Module.
Sorry Stu.. Im just not sure what you are saying..
I think I just realized..
would it not be easier to set a off tigger on the PIR ..  set the delay ON the PIR(Options) to 5 MIN.. When it times out to OFF.. I set another PGM to reflect when it receives an off command.. dim to 50% ??
Easier would depend on your wiring vs. programming preference, but I was responding only to minimizing the delay between the MS sensing motion and the light responding.
The problem with the posted example is the Status of the motion sensor changed to Off before the Wait 5 minutes completes.   The Wait is terminated and the Else clause runs so the Set to 50% is not executed.
Change the If Status to If Control
IF :
And Control  'Front PIR-Sensor' is switched On
IF :
    Then :
Edited by LeeG
