AT&T to end email-to-text ×
Cannot Add Insteon Device
cash70
I am fairly new to home automation.  I currently have the ISY-994/IR PRO and have started to add a few devices (lightbulb linked to a motion sensor and a 2477D dimmer switch to a motion sensor).  I am trying to add a hidden sensor, however, I keep getting "Cannot Add Insteon Device".  I have done some searching and based on what I found, I have performed a factory reset on the hidden sensor and attempted to add via the "New Insteon Device" link.  I still get the same error.  Below is the Level 3 Event Viewer Log.  Thanks for any assistance!
Thu 08/14/2014 07:15:43 PM : [2B 30 5F    ] Added to list of devices to link to ISY
Thu 08/14/2014 07:15:43 PM : [iNST-TX-I1  ] 02 62 2B 30 5F 0F 0D 00
Thu 08/14/2014 07:15:43 PM : [iNST-ACK    ] 02 62 2B.30.5F 0F 0D 00 06                 (00)
Thu 08/14/2014 07:15:43 PM : [iNST-SRX    ] 02 50 2B.30.5F 2C.09.26 2B 0D 02           (02)
Thu 08/14/2014 07:15:43 PM : [std-Direct Ack] 2B.30.5F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Thu 08/14/2014 07:15:43 PM : [iNST-TX-I1  ] 02 62 2B 30 5F 0F 10 00
Thu 08/14/2014 07:15:43 PM : [iNST-ACK    ] 02 62 2B.30.5F 0F 10 00 06          ID-REQ (00)
Thu 08/14/2014 07:15:44 PM : [iNST-SRX    ] 02 50 2B.30.5F 2C.09.26 2B 10 00    ID-REQ (00)
Thu 08/14/2014 07:15:44 PM : [std-Direct Ack] 2B.30.5F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Thu 08/14/2014 07:15:44 PM : [iNST-SRX    ] 02 50 2B.30.5F 10.11.43 8B 02 11           (11)
Thu 08/14/2014 07:15:44 PM : [std-Broadcast] 2B.30.5F-->10.11.43, Max Hops=3, Hops Left=2
Thu 08/14/2014 07:15:44 PM : [2B 30 5F 0  ] Calibrating engine version
Thu 08/14/2014 07:15:44 PM : [iNST-TX-I2CS] 02 62 2B 30 5F 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Thu 08/14/2014 07:15:44 PM : [iNST-ACK    ] 02 62 2B.30.5F 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Thu 08/14/2014 07:15:45 PM : [iNST-SRX    ] 02 50 2B.30.5F 2C.09.26 2B 2F 00           (00)
Thu 08/14/2014 07:15:45 PM : [std-Direct Ack] 2B.30.5F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Thu 08/14/2014 07:15:45 PM : [iNST-ERX    ] 02 51 2B 30 5F 2C 09 26 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 C1
Thu 08/14/2014 07:15:45 PM : [Ext-Direct  ] 2B.30.5F-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Thu 08/14/2014 07:15:45 PM : [2B 30 5F 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0FF8)
Thu 08/14/2014 07:15:45 PM : [2B 30 5F 0  ] Failed to add device, reason 1
Thu 08/14/2014 07:15:45 PM : [2B 30 5F    ] Added to list of devices to link to ISY
Thu 08/14/2014 07:15:45 PM : [iNST-TX-I1  ] 02 62 2B 30 5F 0F 0D 00
Thu 08/14/2014 07:15:45 PM : [All         ] Writing 0 bytes to devices
Thu 08/14/2014 07:15:45 PM : [iNST-ACK    ] 02 62 2B.30.5F 0F 0D 00 06                 (00)
Thu 08/14/2014 07:15:45 PM : [iNST-SRX    ] 02 50 2B.30.5F 2C.09.26 2B 0D 02           (02)
Thu 08/14/2014 07:15:45 PM : [iNST-TX-I1  ] 02 62 2B 30 5F 0F 10 00
Thu 08/14/2014 07:15:46 PM : [iNST-ACK    ] 02 62 2B.30.5F 0F 10 00 06          ID-REQ (00)
Thu 08/14/2014 07:15:46 PM : [iNST-SRX    ] 02 50 2B.30.5F 2C.09.26 2B 10 00    ID-REQ (00)
Thu 08/14/2014 07:15:46 PM : [std-Direct Ack] 2B.30.5F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Thu 08/14/2014 07:15:46 PM : [iNST-SRX    ] 02 50 2B.30.5F 10.11.43 8B 02 11           (11)
Thu 08/14/2014 07:15:46 PM : [std-Broadcast] 2B.30.5F-->10.11.43, Max Hops=3, Hops Left=2
Thu 08/14/2014 07:15:46 PM : [2B 30 5F 0  ] Calibrating engine version
Thu 08/14/2014 07:15:46 PM : [iNST-TX-I2CS] 02 62 2B 30 5F 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Thu 08/14/2014 07:15:46 PM : [iNST-ACK    ] 02 62 2B.30.5F 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Thu 08/14/2014 07:15:47 PM : [iNST-SRX    ] 02 50 2B.30.5F 2C.09.26 2B 2F 00           (00)
Thu 08/14/2014 07:15:47 PM : [std-Direct Ack] 2B.30.5F-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Thu 08/14/2014 07:15:47 PM : [iNST-ERX    ] 02 51 2B 30 5F 2C 09 26 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 C1
Thu 08/14/2014 07:15:47 PM : [Ext-Direct  ] 2B.30.5F-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Thu 08/14/2014 07:15:47 PM : [2B 30 5F 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0FF8)
Thu 08/14/2014 07:15:47 PM : [2B 30 5F 0  ] Failed to add device, reason 1
Thu 08/14/2014 07:15:47 PM : [All         ] Writing 0 bytes to devices
Happy to help.    Comm was too good for the device not to work on an ISY image that came out after the Door Sensor was released.
