2457D2R LampLinc Question
Received my 2457D2R today and had a question. That I later found an older manual that answered my original problem. :oops:
Looked new. Protective covering still on it and no observed blemishes on the case. Though it may have been from some older stock retail kits.
White Sticker:
2457D2R
R3.4
4413
ISY994i reports Firmware v.42
It does not follow the Manual Programming Set Button Sequence Flow Chart. In the Full Users Manual I downloaded.
Wanted to do a Factory reset but can't get to the Column it is in.
Pressed Set Green LED flashes
Pressed Set Red LED flashes.
Pressed Set Red LED still flashes and did not go back to Green flashing for the column Factory Reset and RF Becaon Test is in.
Though the four tap set button sequence did start the RF Beacon Test.
Holding the Set Button at power up until the sounder stopped beeping. Did Factory reset the module.
I found a 2457D.PDF file for the older revisions and the flow chart is not implemented.
So anyone who gets one of the Refurbished LampLincs. It may follow the older manuals information.
Edited by Brian H
