Solved-Are icon plug in dimmers compatible with the ISY
Hi,
I just replaced some X10 gear in the dining room, thanks insteon sale. There are rope lights in the built ins, not Led, that were controlled by smarthome x10 modules. X10 signals from the isy do not reach these reliably. Are icon dimmer modules, 2856d, compatible with the isy. I would prefer not to spend 100 for new dimmer modules for lights that are turned on a few times a year.
Eric
Edit: I did find the icon dimmer in the device list in the isy, missed it the first time.
Edited by EricK
FWIW, I don't have any ICON dimmers, but I'm able to use an ICON relay, 2856S, successfully with the ISY.
As a test I added a 2856D2 to my ISY994i with the Auto Discover method and it worked fine.
As you found. It is in the manual drop down list.
Edited by Brian H
EricK,
The full 2477d INSTEON dimmer switch is currently $38.49. It is higher wattage then the icon switches.
I ordered a few of them to try. These are the plug in modules that won't have much of a load. Non led rope lights.
