Problems accessing control center
Hi,
I used to be able to click on mylighting in the networks folder, then click and open the admin console.  No problem.
Unfortunately, now I have to do it through the website link, or I get an error saying "Missing required Permissions manifest attribute in main jar: http://102.168.1.2/web/insteon.jar"   What does this mean?
When I try doing this on my laptop, wirelessly, I can't even go into admin console from the website.
Your help is greatly appreciated!
Clearwater1957
The following is from an earlier post regarding the ISY not showing up in your network window. Hope this helps
Techman
Hello don4628,
I am so very sorry to hear. Due to security concerns, we disabled UPnP by default. If you would like ISY to show up in your Network window, then you need to go to Admin Console | Configuration | System | Network and check UPnP.
Or, you can simply use:
http://isy.universal-devices.com/994i/admin.jnlp
