dwbourn Posted December 3, 2014 Share Posted December 3, 2014 Has anyone done much research on the new 2-way wireless Elk products coming out? I was looking at buying the transceiver and some glass break sensors but I wasn't sure how serious Elk is going to be about developing new products and such compared to say z-wave, insteon, etc. Any thoughts? --David Link to comment Share on other sites More sharing options...
imagamejunky Posted December 16, 2014 Share Posted December 16, 2014 I'm currently using a number of the new elk 2 way devices without any issues. I have door contacts, motion sensors, smoke detectors, and glass break sensors. So far everything has been working perfectly. Hope this helps. Nick Link to comment Share on other sites More sharing options...
MWareman Posted December 17, 2014 Share Posted December 17, 2014 I'm currently using a number of the new elk 2 way devices without any issues. I have door contacts, motion sensors, smoke detectors, and glass break sensors. So far everything has been working perfectly. Hope this helps. Nick I'm happy to report the same experience with my Elk 2-way wireless equipment. Link to comment Share on other sites More sharing options...
dwbourn Posted December 23, 2014 Author Share Posted December 23, 2014 Sounds great. I will look into this some more. Just wanted to be sure they were solid. Thanks to both of you for sharing your experiences! --dwb Link to comment Share on other sites More sharing options...
shannong Posted December 25, 2014 Share Posted December 25, 2014 I have both Elk Two-Way and Honeywell wireless on my Elk. Both have been rock solid. In theory, I do like the Two-way confirmation of the Elk protocol. I started with Elk only but after initial install I added Honeywell later due to the huge number wireless options. Outside contact closures. Temp/Freeze sensors. Flood Sensors. Tip sensors. A larger variety of contact closures for interior. I also found the range to be better than the Elk. I live in an older home which means shiplap wood behind the drywall, occasional plaster, etc. My furthest sensor from the Elk Two-way was not reliably communicating. Once I added the Honeywell I changed out that sensor and haven't had any issues since. Of course I could've added another Elk Two-Way receiver for better coverage instead of buying the Honeywell but I really wanted the Honeywell sensor options. Especially because at the time there wasn't an Elk glass break sensor, believe it or not. I was also able to use the standard Honeywell 5816 contact closures to make cheap leak sensors. Not only are they cheaper than the Insteon Leak sensors more importantly it's a lot more reliable since it's monitored by my Elk which controls the water shutoff valve so I have leak protection even without power to the house. Link to comment Share on other sites More sharing options...
shannong Posted December 25, 2014 Share Posted December 25, 2014 I wasn't sure how serious Elk is going to be about developing new products and such compared to say z-wave, insteon, etc. Any thoughts? --David Those otherwise wireless protocols aren't appropriate for security alarms and thus don't compete with what Elk, Honeywell, GE, etc are doing. They'll each continue to make their own wireless transmitters/transceivers for the foreseeable future. You investment in Elk Two-way isn't a risky one. Link to comment Share on other sites More sharing options...
