Program Help--Time for dinner
I'd like to get some help on what I think should be a fairly straightforward program, but there are probably several ways to do it, some simpler than others.
I have a KPL at the top of the stairs.  I want to use one of the secondary buttons in non-toggle always OFF mode to activate a program.  The program would be used to call the kids up for dinner or whatever.  We have a music room and a rec room (among others) down there, and I envision a program which flashed the lights three times in both rooms with one second on and then one second off per cycle--and then leaves the lights in the state they were before.  So lets say the kids are in the rec room with lights on and the lights are off in the music room.  That's the way the lights would remain after the program had been activated from the KPL button.
Ideas?
You'll need two programs, one if the light is on and another if the light is off.
Light is Off
     Control 'KPL button' is Off
   And Status 'light' is Off
     Repeat x times
     Set 'light' On
     Wait 1 second
     Set 'light Off
Light is On
   And Status 'light' is On
     Repeat x times
     Set 'light' Off
     Wait 1 second
     Set 'light On
If you want to incorporate the other room then you will need two more programs to satisfy the light status permutations.
On On
On Off
Off On
Off Off
  • 5 months later...
OK, I finally got around to playing with this.  I am doing one step at a time and wrote the progam such that when a KPL button is turned off and a target light is off, it should cycle on and off three times at one second intervals.  The purpose is to call the kids to dinner from downstairs without screaming downstairs through a closed door and over a home theater.
Here's the program.
        Control 'LL - Stairs / Call Upstairs' is switched Off
    And Status  'Great Room - Sconces (North)' is Off
        Repeat 3 times
           Set 'Great Room - Sconces (North)' On
           Wait  1 second
           Set 'Great Room - Sconces (North)' Off
           Wait  1 second
It only cycles one time though.  Here's the event viewer log.  What am I doing wrong?
Sat 05/16/2015 15:24:25 : [  15 C6 8C 5]      DOF   0
Sat 05/16/2015 15:24:26 : [  15 C6 8C 5]       ST   0
Sat 05/16/2015 15:24:26 : [  1A 3A 21 1]       ST 255
Sat 05/16/2015 15:24:27 : [  1A 3A 21 1]       ST   0
As soon as the Program changes the Status of 'Great Room - Sconces (North)' the Repeat is terminated by the Program being triggered with a False state running the Else.
One approach is to put Repeat loop in second Program so the trigger of the first Program does not affect the Repeat.
Thanks Lee, but I'm not following you.  I think I understand what you mean with the False state thing--that rather than runnin g sequentially through the THEN portion and repeating, the change in Status is making the program terminate.  I don't follow how to fix it though.  Do you have time to provide an example?
Repeat and Wait statements can be interrupted by another Program trigger.
Run Program 'Program2' (Then Path)
Program2
Repeat 3 times
Wait 1 second
Wait 1 second
Program2
Repeat 3 times
Wait 1 second
Wait 1 second
You are a good teacher Lee.  That makes sense.  I programmed it as suggested, and it works perfectly.  Thanks.
