CONTROLER BOX MODEL #?
I'm new to the ISY994i.
I order a ISY994i/IR Pro and just received it. My question is on the back of the controller it only shows ISY994i how do I know this is the right model # it doesn't say / IR Pro. The invoice shows it is correct, wanted to know before I start setting it up.
Look in the little hole on the right there should be a weird looking round IR sensor. Plus when you fire it up and select ABOUT it will confirm what it's supposed to be.
NOTE: Even if it's wrong sending in a ticket to UDI with your UUID they can remotely update the (I) to a pro for you.
Encrypted By: Phoenix Security Solutions
Go to Help > About in the drop down menu. It will tell you what version, modules, etc.
Thank you both for the quick answer, I'm out of town on business but when I get home it's jump right in to set-up.
Thanks again.
