ISY 994i v4.2.18 can't link to Insteon 5010L EZSrve module.
Hi,
I hope I'm not asking something obvious, since I couldn't find anything on the 5010L in my searches, I thought I would post.
I've had a number of insteon modules over the years, one is the EZSrve 5010L module, which I have written many a perl script for, and is being used to control lights in my house from my computer.
I recently purchased an ISY 994i to replace my failing EZLinc 2412N which has been used to control the same lights via iPhone. I had the EZLinc and EZSrve linked to allow each to know about the other, with respect to light control....
But when I attempt to do the same with the ISY's 2413S and the 5010L using the Link management drop down in the Administrative Console, I always get an error about unsupported device... Here is a trace I did recently.
Sun 12/14/2014 01:46:16 PM : [91 db 99    ] Added to list of devices to link to ISY
Sun 12/14/2014 01:46:16 PM : [iNST-TX-I1  ] 02 62 91 DB 99 0F 0D 00
Sun 12/14/2014 01:46:16 PM : [iNST-ACK    ] 02 62 91.DB.99 0F 0D 00 06                 (00)
Sun 12/14/2014 01:46:24 PM : [iNST-TX-I1  ] 02 62 91 DB 99 0F 0D 00
Sun 12/14/2014 01:46:24 PM : [iNST-ACK    ] 02 62 91.DB.99 0F 0D 00 06                 (00)
Sun 12/14/2014 01:46:33 PM : [iNST-TX-I1  ] 02 62 91 DB 99 0F 0D 00
Sun 12/14/2014 01:46:33 PM : [iNST-ACK    ] 02 62 91.DB.99 0F 0D 00 06                 (00)
Sun 12/14/2014 01:46:37 PM : [91 DB 99 0  ] Failed to add device, reason 3
Sun 12/14/2014 01:46:37 PM : ---- Start: Generate Scenes from links ----
Sun 12/14/2014 01:46:37 PM : ---- End: Generate Scenes from links ----
Sun 12/14/2014 01:46:37 PM : [All         ] Writing 0 bytes to devices
Hoping someone can help shed some light on what I should be doing to make this work... Is this device something that just simply won't be supported?
  -Chris
The EZServ is not a supported device.
However, the posted trace does not look correct even for an EZServ.
Sun 12/14/2014 05:25:22 PM : [6 4c a5     ] Added to list of devices to link to ISY
Sun 12/14/2014 05:25:22 PM : [iNST-TX-I1  ] 02 62 06 4C A5 0F 0D 00
Sun 12/14/2014 05:25:22 PM : [iNST-ACK    ] 02 62 06.4C.A5 0F 0D 00 06                 (00)
Sun 12/14/2014 05:25:22 PM : [iNST-SRX    ] 02 50 06.4C.A5 22.80.0B 2B 0D 01           (01)
Sun 12/14/2014 05:25:22 PM : [std-Direct Ack] 06.4C.A5-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sun 12/14/2014 05:25:22 PM : [iNST-TX-I1  ] 02 62 06 4C A5 0F 10 00
Sun 12/14/2014 05:25:22 PM : [iNST-ACK    ] 02 62 06.4C.A5 0F 10 00 06          ID-REQ (00)
Sun 12/14/2014 05:25:22 PM : [iNST-SRX    ] 02 50 06.4C.A5 22.80.0B 2B 10 00    ID-REQ (00)
Sun 12/14/2014 05:25:22 PM : [iNST-SRX    ] 02 50 06.4C.A5 00.08.FF 8B 01 00           (00)
Sun 12/14/2014 05:25:22 PM : [std-Broadcast] 06.4C.A5-->00.08.FF, Max Hops=3, Hops Left=2
Sun 12/14/2014 05:25:22 PM : [6 4C A5 0   ] Calibrating engine version
Sun 12/14/2014 05:25:22 PM : [6 4C A5 0   ] May not fully support i2, reverting to i1
Sun 12/14/2014 05:25:22 PM : [6 4C A5 0   ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Sun 12/14/2014 05:25:22 PM : [6 4C A5 0   ] Failed to add device, reason 10
Sun 12/14/2014 05:25:22 PM : [All         ] Writing 0 bytes to devices
