Questions on variables in the Cust Dev tab
paulbates
Hi Benoit
I am working on my Cust Dev tab and had a question. I want to change the Cust Dev tab into a status for my house by just displaying selected variables in locations I create in the device list.
I can get the following to display:
var deviceList =  // This is an example of a table with customizations
            {     location: "HVAC Upstairs",
                list : [
                    { name : "Stage 2 Heat Cycles", labelOn:" ", labelOff:" ", typeControl:"Var", refreshOpt:"Var", varType:"2", varId:"63", varInc:"0", varMax:"0", varControl:"0", varSliderSnap:"0" }
My question is, can i tweak the parameters to display just the variable name and value; no slider or buttons? Formatted similar to the variables tab, but no + -. Attached is an example of what it would look like. I tried adding varControl:"0" but it didn't work for me. Maybe I remove all of the other control related settings like varMax, etc?
Thank you
Paul
Link to comment
Share on other sites
Hello Paul,
All you need to do is add hideControls:"Yes", which does remove all controls (buttons & sliders).
Your device line can be simplified to the following:
{ name : "Stage 2 Heat Cycles", refreshOpt:"Var", varType:"2", varId:"63", hideControls:"Yes" }
Benoit.
Link to comment
