Linking an Insteon wireless Stat after replacing PLM
I have a wireless thermostat that has been used for several months wirelessly and has always worked great when providing the temp to the ISY/mobilinc, etc.  I have it placed in a foyer gable area to provide the temp up there and programed to control a fan to recirculate the heat.  Recently I had to replace my PLM and when I got around to restoring the stat the batteries were dead.  I replaced the batteries and restored the stat.  It is communicating with the ISY according to the event viewer.
The problem is the temp doesn't show up in the admin console.  I've tried everything to get the temp to show with no luck.  Current State, Setpoint and Humidity are all blank.
Any suggestions on how to get it working again?  It isn't and never has been plugged in to AC power.
  • 1 year later...
I'm having same issue, how did you resolve it?
Which specific thermostat?
2441ZTH - i've read that it won't send status until a 2 degree temperature change.  I would have imagined by now I would have had a 2 degree change.  I'm going to test that tonight.
Edited by barkster
What is the result if you put the thermostat into linking mode?
I've relinked it, I've reset it, I've tried everything.  The temp on thermostat shows correctly, it's just not reporting back.  I even got in my hot tub and the temp changed 14 degrees so I know it's not that.  Man everything worked so good before I lost my plm.   I was going to remove it completely from the isy next and re add it.  I don't use it anywhere other than checking temp of hottub.
Edited by barkster
