AT&T to end email-to-text ×
Cannot determine device link table address
iDVB
  1. I put the ISY-994i into Linking mode (PLM Beeps)
  2. I depress the set button under the Insteon Dimmer Switch (Switch Beeps)
  3. PLM then Long Beeps/Squawks (sounds like something did not work)
  4. Then I get this message...  "Cannot determine device link table address"
Weird thing is that I JUST setup my ISY and lights again from scratch and started just with 3 dimmers all on the same wall. All of them worked and then within about 1-2hrs of playing around with it (working) the ISY device for the Dimmer in question got a red exclamation beside it and it kept saying it could not communicate with it.
I've tried factory reseting that dimmer as well as the 4 tap PLM test. The test showed that dimmer blinking green.
Lvl 3 Log...
Sun 12/28/2014 11:08:50 PM : Start Insteon Device Linking Mode
Sun 12/28/2014 11:08:50 PM : [LNK-BGN     ] 02 64 01 00 06
Sun 12/28/2014 11:09:00 PM : [LNK-STAT    ] 02 53 M(01) gid=00 2A.27.22 0120 41
Sun 12/28/2014 11:09:00 PM : [2A.27.22 00] Linked device type=01.20 fw=41
Sun 12/28/2014 11:09:00 PM : [2A 27 22 0  ] Added to list of devices to link to ISY
Sun 12/28/2014 11:09:00 PM : [LNK-BGN     ] 02 64 01 00 06
Sun 12/28/2014 11:09:06 PM : Stop Insteon Device Linking Mode, Final processing to follow
Sun 12/28/2014 11:09:06 PM : [INST-TX-I1  ] 02 62 2A 27 22 0F 0D 00
Sun 12/28/2014 11:09:06 PM : [LNK-END     ] 02 65 06
Sun 12/28/2014 11:09:06 PM : [Std MH      ] Unexpected Ack imCmd=65 cmd1= 0x22
Sun 12/28/2014 11:09:06 PM : [INST-ACK    ] 02 62 2A.27.22 0F 0D 00 06                 (00)
Sun 12/28/2014 11:09:11 PM : [INST-TX-I1  ] 02 62 2A 27 22 0F 0D 00
Sun 12/28/2014 11:09:11 PM : [INST-ACK    ] 02 62 2A.27.22 0F 0D 00 06                 (00)
Sun 12/28/2014 11:09:12 PM : [INST-SRX    ] 02 50 2A.27.22 22.80.71 27 0D 02           (02)
Sun 12/28/2014 11:09:12 PM : [Std-Direct Ack] 2A.27.22-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 12/28/2014 11:09:12 PM : [2A 27 22 0  ] Calibrating engine version
Sun 12/28/2014 11:09:12 PM : [INST-TX-I2CS] 02 62 2A 27 22 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Sun 12/28/2014 11:09:12 PM : [INST-ACK    ] 02 62 2A.27.22 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Sun 12/28/2014 11:09:21 PM : [INST-TX-I2CS] 02 62 2A 27 22 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Sun 12/28/2014 11:09:21 PM : [INST-ACK    ] 02 62 2A.27.22 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Sun 12/28/2014 11:09:23 PM : [INST-SRX    ] 02 50 2A.27.22 22.80.71 27 2F 00           (00)
Sun 12/28/2014 11:09:23 PM : [Std-Direct Ack] 2A.27.22-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sun 12/28/2014 11:09:25 PM : FYP: Connecting to http://flexyourpower.s3.amazonaws.com/banners/status.xml
Sun 12/28/2014 11:09:32 PM : [INST-TX-I2CS] 02 62 2A 27 22 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Sun 12/28/2014 11:09:32 PM : [INST-ACK    ] 02 62 2A.27.22 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Sun 12/28/2014 11:09:36 PM : [2A 27 22 0  ] Failed to add device, reason 9
Sun 12/28/2014 11:09:36 PM : [All         ] Writing 0 bytes to devices
Sun 12/28/2014 11:09:52 PM : [        Time] 23:09:58 0(0)
Sun 12/28/2014 11:10:01 PM : [INST-SRX    ] 02 50 21.09.31 00.00.01 CB 11 00    LTONRR (00)
Sun 12/28/2014 11:10:01 PM : [Std-Group   ] 21.09.31-->Group=1, Max Hops=3, Hops Left=2
Sun 12/28/2014 11:10:01 PM : [INST-DUP    ] Previous message ignored.
Sun 12/28/2014 11:10:06 PM : [INST-SRX    ] 02 50 21.09.31 11.01.01 CB 06 01           (01)
Sun 12/28/2014 11:10:06 PM : [Std-Group   ] 21.09.31-->11.01.01, Max Hops=3, Hops Left=2
Sun 12/28/2014 11:10:06 PM : [INST-DUP    ] Previous message ignored.
Sun 12/28/2014 11:10:25 PM : FYP: Connecting to http://flexyourpower.s3.amazonaws.com/banners/status.xml
Sun 12/28/2014 11:11:25 PM : FYP: Connecting to http://flexyourpower.s3.amazonaws.com/banners/status.xml
Sun 12/28/2014 11:11:36 PM : [INST-SRX    ] 02 50 21.09.31 00.00.01 CB 13 00    LTOFFRR(00)
Sun 12/28/2014 11:11:36 PM : [Std-Group   ] 21.09.31-->Group=1, Max Hops=3, Hops Left=2
Sun 12/28/2014 11:11:36 PM : [INST-DUP    ] Previous message ignored.
Sun 12/28/2014 11:11:42 PM : [INST-SRX    ] 02 50 21.09.31 13.01.01 CB 06 01           (01)
Sun 12/28/2014 11:11:42 PM : [Std-Group   ] 21.09.31-->13.01.01, Max Hops=3, Hops Left=2
Sun 12/28/2014 11:11:42 PM : [INST-DUP    ] Previous message ignored.
Sun 12/28/2014 11:12:25 PM : FYP: Connecting to http://flexyourpower.s3.amazonaws.com/banners/status.xml
Try Factory Resetting the SwitchLinc.  It is not responding correctly.   Extended message (in red below) was not sent from SwitchLinc.
Mon 12/29/2014 01:15:22 AM : Start Insteon Device Linking Mode
Mon 12/29/2014 01:15:22 AM : [LNK-BGN     ] 02 64 01 00 06
Mon 12/29/2014 01:15:41 AM : [LNK-STAT    ] 02 53 M(01) gid=00 33.95.41 0120 44
Mon 12/29/2014 01:15:41 AM : [33.95.41 00] Linked device type=01.20 fw=44
Mon 12/29/2014 01:15:41 AM : [33 95 41 0  ] Added to list of devices to link to ISY
Mon 12/29/2014 01:15:41 AM : [LNK-BGN     ] 02 64 01 00 06
Mon 12/29/2014 01:15:49 AM : Stop Insteon Device Linking Mode, Final processing to follow
Mon 12/29/2014 01:15:49 AM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Mon 12/29/2014 01:15:49 AM : [iNST-TX-I1  ] 02 62 33 95 41 0F 0D 00
Mon 12/29/2014 01:15:49 AM : [iNST-ACK    ] 02 62 33.95.41 0F 0D 00 06                 (00)
Mon 12/29/2014 01:15:49 AM : [iNST-SRX    ] 02 50 33.95.41 22.80.0B 2B 0D 02           (02)
Mon 12/29/2014 01:15:49 AM : [std-Direct Ack] 33.95.41-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 12/29/2014 01:15:49 AM : [33 95 41 0  ] Calibrating engine version
Mon 12/29/2014 01:15:49 AM : [iNST-TX-I2CS] 02 62 33 95 41 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Mon 12/29/2014 01:15:49 AM : [iNST-ACK    ] 02 62 33.95.41 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Mon 12/29/2014 01:15:50 AM : [iNST-SRX    ] 02 50 33.95.41 22.80.0B 2B 2F 00           (00)
Mon 12/29/2014 01:15:50 AM : [std-Direct Ack] 33.95.41-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 12/29/2014 01:15:50 AM : [iNST-ERX    ] 02 51 33 95 41 22 80 0B 11 2F 00 00 01 0F FF 00 AA 00 22 80 0B 00 1C 01 4E
Mon 12/29/2014 01:15:50 AM : [Ext-Direct  ] 33.95.41-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Mon 12/29/2014 01:15:50 AM : [33 95 41 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0FF8)
Mon 12/29/2014 01:15:51 AM : [33 95 41 1  ] Start : Adding device to ISY
Mon 12/29/2014 01:15:51 AM : [33 95 41 1  ] Finish : Adding device to ISY was Successful
      37.7k
      376.7k
