Multiple INSTEON 2334-232 Keypads for one garage door?
I've got two insteon 2334-232's, one is setup to display the status of my garage door and also control the garage door.  I set this up a while ago and used scenes to make it all work.  I'm trying to setup another keypad so that it works the same way.  When I try to add the new keypad to the scene, I receive a message that the garage door is already controlled by the other keypad.  Is it possible to setup two keypads to display and control one garage door?  Thanks.
Yes, you can do that. Tell the ISY that it made the wrong assumption, you do want the new button to be a controller. Our garage doors are controlled by several KPLs as well as a few Remotes.
