How do I turn off all Scenes?
I've got 2 keypad controllers, and for each light control I create a scene:
Scene 1:
  Keypad 1 - B (controller)
  Keypad 2 - B (controller)
  InlineLink 1 (responder)
Scene 2:
  Keypad 1 - C (controller)
  Keypad 2 - C (controller)
  InlineLink 2 (responder)
Scene 3: {just groups the 'H' buttons}
  Keypad 1 - H (responder)
  Keypad 2 - H (responder
The keypads are all Toggle, except for button H which is (send OFF)
Now I want to turn off all scenes with another keypad button (H). I tried a program I found on this site to set the status of H:
      Status 'InlineLink1' is not off
  Or Status 'InlineLink2' is not off
  Set  'Keypad 1 - H' On 15/Off 7
  Set  'Keypad 2 - H' On 15/Off 7
  Set  'Keypad 1 - H' On 0/Off 0
  Set  'Keypad 2 - H' On 0/Off 0
But that doesn't work (the backlight for H doesn't turn on)
I tried another program to turn off all scenes:
      Control 'Keypad 1 - H' is switched off
  Or Control 'Keypad 2 - H' is switched off
  In Scene 'Scene 1' set 'InlineLink1' 0%
  In Scene 'Scene 2' set 'InlineLink2' 0%
But that doesn't work either. The light behind button H flashes on then off, but the scenes don't turn off and the backlights for their controllers remain on.  There is a button in the ISY console to turn a scene off, but there doesn't seem to be any corresponding action.
If Control 'kpl 1 button H' is switched Off
Or Control 'kpl 2 button H' is switched Off
   Set Scene 'Scene 1' Off
   Set Scene 'Scene 2' Off
   Set Scene 'Scene 3' Off
Ah! I was looking in the "Adjust Scene" actions, but Scene Off is in the "Insteon" actions.
Thanks. Any ideas for part 1 (status lights)?
Part 1 is turning on the status light for button H when any of the scenes are active (first program above)
If Control 'kpl 1 B' is switched On
Or Control 'kpl 2 B' is switched On
Or Control 'kpl 1 C' is switched On
Or Control 'kpl 2 C' is switched On
    Set Scene 'Scene 3' On
If Status 'kpl 1 B' is Off
And Status 'kpl 2 B' is Off
And Status 'kpl 1 C' is Off
And Status 'kpl 2 C' is Off
Thank you. 'Control' is a trigger. 'Status' is not. (the guide could be a little clearer on that).
If Control and If Status are both triggers.  Both can trigger a Program to Run
If Control is looking at the commands flowing from the device.
If Status is looking at Current State of the device.
Edited by LeeG
The ISY (I'm using firmware version 4.2.18) seems to only run a 'Status' program once. I'm using your post #6 (If Control 'Keypad 1 - B' is switch on, etc.) to run the program that is all Status checks, and that works, since every change of state seems to trigger a Control check, but not a Status check.
But there is an interesting timing issue here (for us programmer types). pressing Kp1-B, to turn it on, turns on InlineLink1 in the scene, but also triggers the program that then checks the status of InlineLink1. Do we know that the scene update completes before the program is run? Or is there a chance that the program might find the InlineLink1 to still be off?
If Control and if status have their own set of rules.   If Control triggers the Program when the inbound command matches what is being looked for, On in this case.  If Control does not trigger a Program when the device/button is turned On by something  other than the device paddle/button being pressed On.
If Status triggers a Program when the Current State changes to match the condition being checked for.  If Status does not trigger a Program when Current State does not change states.   Turning a device/button On twice in a row triggers the Program once when Current State changes to On.
The Program(s) that are checking Responder Status of InlineLincs should be deleted.  No need to monitor a Responder.
So I should be monitoring the Status of the associated controller, instead? (e.g. Kp1-B, KP2-B ). Do I need to monitor both, since both are controllers in the same Scene and so should be linked?
Edited by MarcK
Yes. But do I need to monitor both keypads? Since Kp1-B and Kp2-B are both controllers for the same scene, I should only need to monitor one of them. (This is for the 'else' part of post #6)
Both KPLs are being monitored by the two Programs in post 6.
Neither Program in post 6 uses/needs anything in the Else clause.  The first Program turns On Scene 3 (turns On both H buttons) when any of the 4 KPL buttons is turned On.  The second Program turns Off both H buttons  when all four KPL buttons are turned Off.
Oops, i see the missing piece.
If Control 'kpl1 H' is switched Off
Or Control 'kpl2 H' is switched Off
Assumption - Scene 3 is assigned to kpl1 H and kpl2 H
For reference -  setting Backlight level changes the button LED level for All buttons, not just button H
The Adjust Scene changes the Responder On Level or Responder Ramp Rate of the Set device the next time the Scene is used.   Does not turn On/Off the Set device.
Edited by LeeG
