Motion Sensor + Light, light not turning off
I know there are tons of examples out there of using a motion sensor to control a light, but I want to know why this simple example doesn't work...
The light always turns on, but often will not turn off:
IF
  Status 'Motion-Sensor' is On
THEN
   WAIT 5 Minutes
   Set Light On
   WAIT 10 Minutes
   Set Light OFF
ELSE
If I change the WAIT to seconds instead of minutes, it seems to work fine.
My only thought is that there is something happening with concurrent runs - in other words the motion sensor is sending another Status 'Motion-Sensor' is On before the program finishes.
How does the ISY treat concurrent runs of the same program? Is the original killed and a new one started? Is the new one ignored? Do they run concurrently?
Try Control instead of Status.
"How does the ISY treat concurrent runs of the same program? Is the original killed and a new one started?"     Yes.
The Program is triggered when Motion Sensor Status changes.  This terminates the current Program (which is why the lights do not turn off) and the If is evaluated again.  It is likely False (need MS settings to confirm) so the Else is driven.
EDIT: The termination of the current program execution occurs when the Program is in a Wait or Repeat.  If there is no Wait or Repeat the running clause (Then or Else) runs to the end.
Edited by LeeG
fahrvergnuugen,
Split your program into two programs. The first program will trigger the 2nd program. Once triggered, the 2nd program will run its course even after the motion sensor shuts off.
IF
  CONTROL 'Motion-Sensor' is On
THEN
 RUN PROGRAM 2 then clause
 ELSE
   (blank)
Program 2
IF
  (blank)
THEN
   WAIT 5 Minutes
   Set Light On
   WAIT 10 Minutes
   Set Light OFF
ELSE
   (blank)
Edited by Techman
