How to add a button to MobiLinc via the ISY99 to turn on TV
Hi, I'm new to this and have tried via the Wiki to get it to work.
Problem:
Turn on our Sharp 80" big flat screen LED TV
We have a ISY994ipro with the IR module installed.
I'm in the Universal Devices Admin console
Under
Programs
Details
My Programs
I have a Program called "Sharp Turn On"
The program is as follows
If IR (362) is pressed
Then Run Program "Sharp turn on" (if)
Else No Actions (TO add one, press action)
Now I'm stuck, how do I create a button to run this program? where or what do I do next?
Thank you for the advice
Under Configuration | IR  there is a Enter Learning Mode button.  The process is covered in the ISY User Guide.
The IR codes should be RC5 (used by Philips) based.  I don't know what type IR codes are used by a Sharp TV.
