How to turn on lights for 10 seconds with motion sensor?
Should  the time the lights stay on be controlled by the options of the motion sensor itself (which im doing now) or by a wait command.  Can someone recommend the best way to do this?
Using the properties of the MS results in a quicker response. A program makes it easy to change the on duration.
Set the motion sensor options to send an On only.
Program
        Control 'Motion Sensor' is switched On
        Set 'scene with light' On
        Wait x hours, y minutes, z seconds
        Set 'scene with light' Off
Yes, it will. You'll need a more sophisticated program that either won't run if the light is already on or will run only when the light is off.
How would I disable the motion sensor when I open the door so I can have the lights stay on longer when I enter the house and the door sensor is triggered?
