Send Scene ON without changing state of Keypad Linc button
Many apologies if this has already been hashed out, but I was wondering if there was a way to send a Scene-On command while keeping a keypad linc button in the off state?  I basically have a 6-button dimmer that I am trying to prevent the scene buttons from changing state.  Just want them to fire up a scene and then go back to an off state (if you will)
Thanks in advance.
A program can turn off the button LED.
Create a scene with only the button(s) as responders. Then write a program that turns the scene off about 2 seconds after the Scene-On command is sent. The 2 second delay avoids signalling collisions.
My inclination would be to configure the buttons as non-toggle (off) and trigger a program from the button OFF command to turn on the scene.
I do just this for a few scenes. I always want to be able to press the button and turn the scene on. I would put the button in non toggle on mode and use it as a controller of the scene. Create a scene "kpl button"
Then use a program
If control button is on or
Status button is on
Then set scene "kpl button" off
