Curious Folder Items
Wondering what "Auto DR" is - and also what the folder with a different icon matching the name of my ISY?  Both are circled in the attached image.
Auto DR
Murry Mansion is the name you gave your home. IIRC, it was originally My Lighting.
Thanks Stu, but I understand that.  There is an additional folder ... also named Murray Mansion that has a different icon.  Nothing in it.  It may have had some items in it but I moved them - not sure - maybe zwave items.
Thanks for the link on "Auto DR"
If you have a folder with the same name, then you probably funtime created it. If it's empty, then you can safely delete it. Or rename the folder , for example, Murry Table, and populate it B)
Edited by stusviews
Look at page 15 in ISY User Guide for what it looked like originally.  "Network" is/was the first Icon with "My Lighting" the second.  My Lighting indicates the configuration came from a 99i that was migrated to a 994i.  A configuration totally from a 994i has "ISY" rather than "My Lighting"
