View/Set Elk Alarm State with KeypadLinc
Hi,
I have a button on my KeypadLinc labeled 'Alarm'. I added this to a new Scene called 'AlarmScene'
When the Elk is Armed, I want the button to be On (I replaced it with a red LED for effect).
To accomplish what I want, I wrote a simple program
   Elk Area 'Home' 'Armed State' is not Disarmed
   Set Scene 'AlarmScene' On
   Set Scene 'AlarmScene' Off
I also want to be able to Turn ON the alarm by pressing the button, but not turn it off. To do this I wrote this program
   Control 'Keypad - Alarm' is switched On
   Set Elk Area 'Home' Arm Night Instant
   Set Elk Area 'Home' Query
My problem is that when I press the button on the KeypadLinc itself, it turns the button 'Off' and the Query is not turning it back On.
Any idea the best way to set this up?
The "If Control" as written has a True only evaluation so the Else clause is never executed.
And Control 'Keypad - Alarm' is not switched Off
Tried adding that with no luck. Is it possible that the 'Query' doesn't trigger the first program in some way?
The light is set correctly when Arming/Disarming every other way (Security Keypad, Via Mobile Phone App, etc..). I just don't want the light to turn off when I press the key unless it really is disarmed?
I simply changed it to run the 'Alarm Status' and it works.
     Run Program 'Alarm Status' (If)
