error log
Hi
I am having a problem opening the error log file. I can erase but, if I try to view it it gives me request failed or nothing.
Is it because it's empty, not created ?
Version release 4.2.27 rc4.
How are you trying to view the error log?
If you erase the Log or Error Log. They are blank. You will get  an error if you try and access the empty log. Until the log has had some data added to it. Then you should be able to again view what is in the log.
