Help with keyfob programming.
bobmre
I use a dummy output for this combined with an Automation Rule. The outputs above 65 aren't "real" unless you have an expander attached. However, you can still tell the Elk to turn them On/Off and the ISY can see that status change.
I have an Automation Rule that says something like this:
When RF Key Fob Button 3 Is Activated
Then Turn Output 200 On for 2 Seconds
Now you can write an ISY program that says:
If Elk Output 200 is On
Then  <whatever you want>
      37.6k
      376.2k
