How do you set on levels for certain times of day? (Solved)
Is the switch a CONTROLLER or RESPONDER in the scene definition?  You may need to remove it from the scene, and re-add it as CONTROLLER.
Given that your remotelinc button is a controller in that scene, do you also want the ON levels to change when activated by this button?
No just the light switch
The switch must be a Red Controller in a Scene to appear in the In Scene devices.  Only devices that have been defined as Red Controllers in a Scene are in the In Scene list.
That was the problem.  I changed them all to controllers, but only after I reopened the ISY would all the lights appear on the list.  I tested it and everything works great.
Thanks so much for your time and help, guys!
