Trane Zwave Thermostat issue TZEMT400BB32
I have 3 identical Trane TZEMT400BB32 Thermostats
All 3 have code version 1.01.40, Zwave version 2.00.09
All 3 were working fine together on a Vera 3 network
I was attempting to move them one at a time from the Vera to my new ISY994
The first one Included to the ISY fine after moving the ISY VERY close to the thermostat
Number 2 is the issue, don't want to move 3 until I understand
Does anyone have more than one of these thermostats on their ISY Zwave network ?
Number 2 excluded fine from the Vera that apparently has a Zwave home ID of f7.d4.ec.85
I have tried multiple times to include number 2 on the ISY
Each time I do, it takes on the home id of d3.c1.df.1c which matches number one, so number 2 has the ISY network
Each time the Znode increases by 1
the Log information is .....
Wed 04/08/2015 03:16:21 PM : [uZW-CMD 1       ] Start Include
Wed 04/08/2015 03:16:21 PM : [VAR  2   23 ]       1
Wed 04/08/2015 03:16:21 PM : [ZWAVE-RX        ] ACK
Wed 04/08/2015 03:16:21 PM : [ZWAVE-RX        ] [0107004A3F010000]...
Wed 04/08/2015 03:16:21 PM : [ZWAVE-TX        ] ACK
Wed 04/08/2015 03:16:21 PM : Listening for Z-Wave devices to add to the network
Wed 04/08/2015 03:17:07 PM : [ZWAVE-RX        ] [0107004A3F020000]...
Wed 04/08/2015 03:17:07 PM : [ZWAVE-TX        ] ACK
Wed 04/08/2015 03:17:07 PM : Z-Wave device detected, retrieving info 2
Wed 04/08/2015 03:17:07 PM : [ZWAVE-RX        ] [0116004A3F032D0F]...
Wed 04/08/2015 03:17:07 PM : Z-Wave device detected, retrieving info 3
Wed 04/08/2015 03:17:09 PM : [ZWAVE-RX        ] [0107004A3F052D00]...
Wed 04/08/2015 03:17:09 PM : [ZWAVE-TX        ] ACK
Wed 04/08/2015 03:17:09 PM : Z-Wave device detected, retrieving info 5
Wed 04/08/2015 03:17:09 PM : [ZWAVE-TX        ] [0105004A854075]
Wed 04/08/2015 03:17:09 PM : [ZWAVE-RX        ] ACK
Wed 04/08/2015 03:17:09 PM : [ZWAVE-RX        ] [0107004A40062D00]...
Wed 04/08/2015 03:17:09 PM : Adding Z-Wave devices stopped
Wed 04/08/2015 03:17:09 PM : [ZWAVE-TX        ] [01030020DC]
Wed 04/08/2015 03:17:09 PM : [ZWAVE-RX        ] [01080120D3C1DF1C]...
Wed 04/08/2015 03:17:09 PM : [ZWAVE-TX        ] [01030005F9]
Wed 04/08/2015 03:17:09 PM : [ZWAVE-RX        ] [0104010500FF]
Wed 04/08/2015 03:17:09 PM : Device 45 of type 4.8.6 included into Z-Wave network
Wed 04/08/2015 03:17:10 PM : [ZWAVE-TX        ] [010900132D027204]...
Wed 04/08/2015 03:17:10 PM : [ZWAVE-RX        ] ACK
Wed 04/08/2015 03:17:10 PM : [ZWAVE-RX        ] [0104011301E8]
Wed 04/08/2015 03:17:10 PM : [ZWAVE-TX        ] ACK
Wed 04/08/2015 03:17:10 PM : [ZWAVE-RX        ] [010500134100A8]
Wed 04/08/2015 03:17:14 PM : [ZWAVE-TX        ] [010900132D027204]...
Wed 04/08/2015 03:17:15 PM : [ZWAVE-RX        ] ACK
Wed 04/08/2015 03:17:15 PM : [ZWAVE-RX        ] [0104011301E8]
Wed 04/08/2015 03:17:15 PM : [ZWAVE-TX        ] ACK
Wed 04/08/2015 03:17:15 PM : [ZWAVE-RX        ] [010500134100A8]
Wed 04/08/2015 03:17:19 PM : [ZWAVE-TX        ] [010900132D027204]...
Wed 04/08/2015 03:17:19 PM : [ZWAVE-RX        ] ACK
Wed 04/08/2015 03:17:19 PM : [ZWAVE-RX        ] [0104011301E8]
Wed 04/08/2015 03:17:19 PM : [ZWAVE-TX        ] ACK
Wed 04/08/2015 03:17:19 PM : [ZWAVE-RX        ] [010500134100A8]
Wed 04/08/2015 03:17:24 PM : Cannot get manufacturer specific data
The device does not appear in the Admin Console or on MobiLinc
I have a hard time believing the thermostat is bad since it works fine with the Vera
Any ideas anyone  ?  or does anyone have more than one instance of this thermostat working on their ISY ??
Thanks in advance
...Barry
You said you excluded from vera...did you exclude from isy too?
Unintuitive zwave behavior, but it has been reported many times with many controllers.
Exclude before you include. Maybe that will help.
Multiple times
Believe this unit started out as Zwave unit 29, I am up to 37 I have tried so many excludes / includes
If it wasn't excluded, I don't believe it would get that far in the include before crashing
I've checked with our manufacturer contact to see if there is any anomalies with this version. Awaiting a reply....
I'd recommend trying again by removing thermostat one and putting thermostat two in its place, then pair it. Then put thermostat two back in its place. You should be able to pair thermostat three in its final location with the other two added if not move thermostat 3 to location one and pair again. I confirmed the Z–wave communications of these thermostats are identical to a RCS TZ45 and they work flawlessly in every situation I've run across.
Sorry for brevity - posted using mobile Tapatalk
Edited by mikeiud
Well that makes no sense at all. When I had thermostat #2 3 inches from the ISY it would not include.  When I moved it to the location of thermostat #2 to the location of number 1 and put the isy 3 inches away it included fine. Same with thermostat # 3
There has to be something driving that behavior
After the heal 1 and 2 work fine, 3 still cant communicate, I assume that is a zwave network thing,  will play with that
thank your for all the help and would love an explanation
..Barry
Barry,
You might want to take a look at what ELSE is on your z-wave network that might be causing communication issues.  Can you please post the results of the following command for one of the thermostats that are working correctly? (1 or 2)
Open up event viewer, clear it then show full info and paste here
Thanks for looking into it
Here is the result from thermostat 1
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ] ----------------------------------------------
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ] ZW015_1 uid=15 type=4.8.6 mid=139 tid=21586 pid=21555 model=0
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    -  x40  V1  THERMOSTAT_MODE
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    -  x42  V0  THERMOSTAT_OPERATING_STATE
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    -  x43  V1  THERMOSTAT_SETPOINT
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    -  x44  V1  THERMOSTAT_FAN_MODE
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    -  x45  V0  THERMOSTAT_FAN_STATE
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    -  x70  V1  CONFIGURATION
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    -  x31  V1  SENSOR_MULTILEVEL
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    -  x86  V0  VERSION
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    -  x81  V0  CLOCK
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    -  x72  V1  MANUFACTURER_SPECIFIC
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    -  x76  V0  LOCK
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    -  x85  V1  ASSOCIATION
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]   Thermostat Mode Mask     = x001F
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]   Thermostat Fan Mode Mask = x0003
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ] Node  15 - Living Room Thermostat has the following neighbors
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node   2 - Kitchen Undercabinet Lights
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node   3 - Kitchen Coffee Pot Outlet
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node   4 - Brultech Power Switch
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node   5 - Formal Living Room Fan
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node   6 - Formal Living Room Fan Light
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node   7 - Dishwasher On-Off Power Switc
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  10 - Garage AV Switch
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  11 - Garage Battery Charger
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  16 - Patio Fans
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  18 - Patio Fan Lights
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  19 - Living Room Fan
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  20 - Living Room Fan Light
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  21 - Living Room Niche
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  22 - Right Rear Speaker
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  23 - Left Rear Speaker
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  24 - Garage Lights
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  26 - Office Power
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  28 - ZW 028 RepeaterGrear Room
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  29 - Slingbox Power Switch
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  30 - Gun Safe Power Switch
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  31 - ZW 031 Repeater FLR
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  41 - Master Bath Popout
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    - Repeater - Node  43 - Master Bedroom TV Switch
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ] Node  15 - Living Room Thermostat has 1 association group
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]    Associations for group 001 of ZW015_1 Living Room Thermostat
Fri 04/10/2015 05:22:14 AM : [ZW-SHOW         ]       - Node   1 - [This ISY]
Looks like a robust network! By any chance are some of these devices GE Jasco?
at the time, there were 3 Ge/Jasco duplex outlets in the network. I have since found they were sending transmit errors for no good reason and have taken them out of the network. I do still have some Ge light switches and dimmers, but have not seen issues with them. Why do you ask ??
..Barry
This is by no means scientific, but I have found that after several tests having my first gen Jasco outdoor module on my network was a problem. Any device that had it as a neighbor would fail. Once removed my network worked flawlessly.
