6-Button Keypadlinc Shows up as 5-button device
I have two 6-button keypadlinc keypads and they show up as 5 buttons in the ISY.
Not sure why or what to do? I'd like to program all 6 buttons - ON, OFF, A, B, C, D.
When the ISY found and created these devices, it created .1, .A, .B, .C, .D. I am guessing that the .1 is the on button and I am using the A-D buttons. How do I access the OFF button?
Using programs (do not use the On/Off buttons a a scene controller):
     Control 'device' is Switched On
     do what you want
and
     Control 'device' is Switched Off
     do what you want
Using scenes:
1. Change the mode to 8-button, use the 6-button frame and buttons. The ISY will see the buttons as A through H.
2. Make both A & B the controller of any scene
3. Make both G & H the controller of any scene
4. Buttons labelled A, B, C, and D will actually be buttons C, D, E, and F
Edited by stusviews
