Leak Sensor, 2852-222, does not show Heartbeat Node
I have 3 Insteon Leak detectors that I had set up with my initial isy99i setup.  I had the Wet & Try nodes show up in the device tree, and I figured all was fine until a friend asked what the Heartbeat node was on his.  I don't show the heartbeat node here.
I converted my entire configuration over to my new 994i when I got it several months ago.  Was addition of monitoring Heartbeat a new 994i thing? or a newer firmware on the leak detector?
Is there any way to get the node added without removing and adding the device?  I don't want to have to go back and tune my programs that reference the leak detectors, if i can avoid it.
I have v.3E and v.43 Leak Sensors, both have the Heartbeat node. No idea what 3.3.10 did with those levels.
Must Delete and add the Leak Sensors back to get the Heartbeat node. Note that 4.2.30 is now the latest Official release.
