cannot backup ISY
I am running 4.2.18 (latest official release) on a Mac (OS X 10.10.3 latest) using Safari.  I also recently (a few days ago) did a Java update to version 8 update 45.
I make small changes to my programs from time to time and do a "backup ISY" each time.  This morning I have done a small programming change but cannot do a backup.  I see an incomplete open file dialog box, choose the Documents folder.  I receive a message "cannot create zip file".
I did do a complete delete of all Java temporary files after the recent Java update.
It would be best if you created a service request to UDI to facilitate a solution in this regard.
Having had a problem similar to this some time ago, try backing up to your desktop then moving the file to where you wish.
I use a Mac as well.
I have found the solution.
Go to Safari/Preferences/Security/Internet Plug-ins/Website Settings
For Java/IP-address-ISY select "run un-trusted"
Close all the windows and Safari.  Re-open the admin console and the backup should be able to be done normally.
I have done this setting before, but it must have been lost in an OS X update.
Edited by drw
