day time light program
Hi
I have a few lights that I have set to come on to only 75 % between sunrise and sunset, each light has it's own program.
If switched on
then set to 75 %
The programs are in a folder that I have that says
If from sunrise to sunset
then allow programs in this folder to run
all work fine but one light. It will not go to 100 % after sunset when switched on unless you do a fast on first, then it will go to 100 % until after sunrise the next day
All switches are dimmers, V.41
any help
Thanks Jeff
Jeff,
Can you post the program that turns on the light you're having an issue with.
The light is coming on at the default level you have set for that switch.
You don't seem to have anything that returns the level to 100%.
Hi
Not sure how to post the programs, I have five programs that are in a folder. the folder says, If from sunrise to sunset the same day, then allow programs in this folder to run.
the programs in the folder are all the same
If  control xxxx is switched on
then set xxxx 75 %
 4 work , turn light to 75 % between sunrise and sunset, turn to 100 % any other time
1 works as follows turns to 75 % between sunrise and sunset, after sunset it will still go to 75 %, if I do a fast on then will go to 100 %, then it will always go to 100 % with a on single tap untill the next sunrise and sunset run time. it seems to need that fast on to reset it . any thoughts
The SwitchLinc has two modes of local operation. In one mode it turns On to the last On level. It sounds like that SwitchLinc is operating in that mode, going to 75%. That is why Fast On going to 100% becomes the last local On level. Check the User Manual for how to change the local mode operation.
Hi
Thanks for the advice. I did a reset and restore and now it works fine
Jeff
