Local On-Level keeps setting itself
I have a switchlinc that keeps setting it's local on level to (I'm guessing) 20%.
I have two programs that control this light (it's not included in any scenes) that are as below.
        From    Sunset
        To      Sunrise (next day)
    And Status  'Motion Sensors / Upstairs Bath-Sensor' is On
    And Status  'Upstairs Bath' < 1%
        Set 'Upstairs Bath' 20%
        Status  'Motion Sensors / Upstairs Bath-Sensor' is Off
    And Status  'Upstairs Bath' is 20%
        Wait  3 minutes
        Set 'Upstairs Bath' Off
Every time I run these programs then turn the light on locally, it only comes on at 20% but the ISY shows it at 100%.  If I air gap the switch, local level is back to 100%  I can also adjust the local level in ISY (set it to 0 then back to 100) and its good until the next time the program runs.
Any ideas why this is happening?
There is nothing that's returns the device to 100%.
I want it to go to 100% when I turn it on by hand (the paddle).  Both of those programs are in a folder that are true only late at night.
The SwitchLinc Local On Level has two modes of operation that are set with the SwitchLinc itself.
Local On-Level
Default = 100% (fixed brightness) The local on-level is the brightness that SwitchLinc’s connected load will come on when turned on at SwitchLinc paddle. Local on-level can be set to any one of 32 fixed brightness levels (3% to 100%) or “resume bright” (brightness prior to last being turned off).
Page 12 of 17 Rev: 7/24/2012 10:26 AM
To set local on level to a fixed brightness level
1) Adjust SwitchLinc to desired brightness when controlled locally
2) Tap Set button
SwitchLinc will beep
3) Test by turning SwitchLinc off and then back on (via the paddle)
SwitchLinc will turn on to new local on-level
To set local on level to the brightness level prior to being turned off
1) Turn SwitchLinc off
2) Tap Set button
3) Test:
a. Brighten SwitchLinc to a random brightness level (e.g. 75%)
b. Turn SwitchLinc off
c. Turn SwitchLinc back on
Light will turn on at the defined brightness level
It was set to remember the last on level. I have no idea how that got set.
