db2ace2 Posted May 17, 2015 Share Posted May 17, 2015 Just a suggestion for Enhancement. FANLINC needs to have a short wire with a Reset Switch that can be left outside of a Fan Housing that contains the FANLINC. It is way too cumbersome to have to go into the Fan Shroud just to reset the Fanlinc or Program it. If there was a small Reset /Linking mode wire that could be left outside the housing it would be great! Thanks Charles Seiler Link to comment
stusviews Posted May 17, 2015 Share Posted May 17, 2015 db2ace2, this is an ISY users forum. You may want to make your suggestion to the manufacturer/seller of the FanLinc. Link to comment
G W Posted May 17, 2015 Share Posted May 17, 2015 Humm. I have several FanLincs and I've never had to reset one. What I want is two light controllers built in and a relay control for forward and reverse. Link to comment
