How Can I trigger a program from a Button on a 6-Button Control
I want to set up a button on a 6-button control to turn on a circuit at 6:30 the next morning and then not do it again unless I press the button again.
I tried this:
And it does not do anything.
Your requirements:
If one presses a button, then turn something on once, when it is 6:30am.  Correct?
status button C is ON
and
time is 6:30am
then
turn something on
set button C off
else
nothing
I think you came very close with your attempt.  Try "STATUS" rather than "CONTROL" for your towel warmer button.
Thanks, that was the problem.
