Is there a way to create a Scene that only executes a program ?
I have a program that uses a Wifi2IR to turn off the kids TV automatically at midnight via IR
Would like to have a "Scene" Switch on mobilink to do the same manually
I cant seem to figure out how, is there a way ??
Thanks in advance
...Barry
A scene cannot initiate a program, but you can use MobiLinc to run the program directly.
I don't believe the WF2IR can be a part of a scene.  Scenes are pretty much the domain of insteon devices (though I think z-wave will respond to scenes when run from the admin panel).
You could create a scene (perhaps even a single-device scene I suppose) then use the "status" of one of the scene devices to trigger a program which turns off the TV.  Unfortunately, I don't recall that there are dummy scenes on mobilinc.  There will have to be an actual insteon device in the scene.
Or, you could just run the program directly as suggested by stusviews.
