Programs using parentheses issues
I am trying to control the lights in my closet with hidden door sensors on each of the two doors to/from the closet.
2x 2845-222 configured as two nodes each in each door
1x 2477D controlling the load on the lights
ISY994ZW 4.2.18 Firmware
The 2477D is between the two sensors and there is less than 5' from sensor to switch.
I am trying to set up the system so the lights will come on if EITHER door is opened and only go off if BOTH doors are closed.
Making the lights come on is simple with a single scene containing the two 'Door Open' nodes as controllers and the switch as a responder.
Making the lights turn off has proven more of a challenge.
I wrote a program to control this and is shown below:
             Control 'Main Floor / Master Closet / Master Bathroom Door Sensor / Door Closed' is switched On
         And Status  'Main Floor / Master Closet / Family Foyer Door Sensor / Door Closed' is 100%
     Or (
             Control 'Main Floor / Master Closet / Family Foyer Door Sensor / Door Closed' is switched On
         And Status  'Main Floor / Master Closet / Master Bathroom Door Sensor / Door Closed' is 100%
        Wait  1 second
        Set 'Main Floor / Master Closet / Can Lights' Off
This does not work as desired.
But, if I copy the program above twice, and edit each as below:
        Wait  1 second
and
        Wait  1 second
then I get the desired behavior.
I know the parentheses are not required in the two split programs, but I left them in to verify they were not causing a problem.
Why does my single program not behave as I expect?
I think I have answered my own question. Writing the original post helped me think it through.
I think the problem is a combination of using 'Control' rather than 'Status' and also introducing the 1 second wait.
I assume that while the Control will trigger the program and the wait will begin, at almost the same moment, the Status will also change which re-runs the program and cancels the wait. Since when the status changes, the Control of the other door has not changed, then neither logic path equates to TRUE and hence the 'Then' is never triggered.
I changed my program to:
        Wait  1 second
and all is well.
Hope this helps someone else in the future :-)
Edited by mcqwerty
