changed router and cannot log in (probably easy answer)
All,
Had to change from my router to the ISP modem/router and I cannot access my ISY.  I assume this is from the IP Change, any help would be appreciated.
Browse to http://isy
If that works or not then post back. We'll go from there.
Nope, takes me to some website
Update: cycled the power and I got it,, duh.
Edited by Waketech
That's great.
Browsing to http://isyshould not take you, "to some website." Unless you set a port, you should arrive at the ISY Dashboard. Did that not happen?
It took me to www.isy.com, after I cycle the power on the ISY it took me to the right place, not too sure what happened there
