Admin console can't find my ISY-994i
My brother's Android phone using Mobilinc developed a problem connecting over the WiFi (it has done so successfully in the past, but that app seems... unreliable). In an attempt to fix it, I changed the local port from 80 to another number in the phone and the ISY-994i - you try things to see if one of them will work.
This was apparently a Very Bad Idea, as now I cannot now get the Admin console to work. As far as I can tell the ISY is working (I'd have to wait until a timed event actually occurs later today to be sure), but clicking the Admin console icon brings up the ISY Finder, which has no entries in its list. I tried disconnecting the power to the ISY, no dice. I tried Refresh several times. I tried Add and then typing the URL (which I verified by checking my router's configuration page). I tried it with just the four octets (in my case, 192.168.1.16) and with the four octets, a colon, and the port number (as you'd do in a web browser). All it tells me is "Invalid URL". I'm not sure what goes in "Enter URL" if it's not an IP address.
Has anyone else make this mistake, and do you know how to fix it?
EDIT: Never mind. Apparently what goes in Enter URL is "https://octet1.octet2.octet3.octet4:port".Note the "s" for secure. That's what finally found it. I assumed, incorrectly, that because the Administrative console and the ISY were both behind the firewall/router that it would use "http:".
Edited by Balok
  • 10 months later...
Thank you thank you thank you!   I was losing my mind doing exactly what you did.   Now all fixed & happy.
