Weather problem
richardl007
I have a very simple program that sets a variable if the average temperature drops below 5c. I use this variable to run or not to run programs.
If module 'climate' average temperature <=5c
I'm in Montreal Canada and we are in the middle of the summer and the average temp doesn't go anywhere near 5c , but every night this program runs and sets the variable wrong.
Does it run at the same time every night?  If so, perhaps this might be a clue as to the cause.  (Specifically, I wonder if ithis is being triggered by a nightly query or some other programmed event.)
I attached  some pictures.  Hopefully these answer your questions.
Are you using a state variable or an integer variable?.  A program can only be triggered by a state variable.
Take a look at your variable to make sure it's properly initialized.
Being that your weather data is coming from Montreal Airport is should be reliable. You might want to take a look at your error log to see is there's any HAM Weather related errors.
      38k
      379.3k
